Superhub 3 Power Levels
Luvey
Can anyone take a look at these power levels and tell me if they are ok or not?
Upstream
1603000003.6512064 qam1
2394000003.5512064 qam4
3462000003.55512064 qam3
4537000003.6512064 qam2
Downstream
141100000023.538256 qam31
219500000023.940256 qam8
320300000023.640256 qam9
421100000023.540256 qam10
521900000023.840256 qam11
62270000002440256 qam12
723500000023.940256 qam13
824300000023.640256 qam14
925100000023.340256 qam15
1025900000023.540256 qam16
1126700000023.538256 qam17
1227500000023.840256 qam18
1328300000023.540256 qam19
1429100000023.840256 qam20
152990000002440256 qam21
1630700000023.838256 qam22
173150000002440256 qam23
1832300000023.640256 qam24
193630000002438256 qam25
2037100000023.940256 qam26
2137900000023.840256 qam27
2238700000023.940256 qam28
2339500000023.540256 qam29
244030000002438256 qam30
22 REPLIES 22
Those downstream are sky high, should not be greater than 10. You probably need an attenuator inserted, this should be done by a technician. You should phone customer services urgently.
I have a 10db attenuator  and a 15db attenuator  here from my superhub 2. Which one should i connect?
Eeeps
Well-informed
Both! Now!
You could probably run your electric car or those power levels.
I added the 15db one and my downstream levels are around 8 dBmV now. Is that acceptable or will I experience problems?
Downstream: no lower than -6dBmV and no higher than 10dBmV - Close to 0 is optimal. SNR >33
Thanks! Can you tell me what kind of problems it would cause with high downstream levels?
Andrew-G
High power levels cause a range of symptoms: Unstable connections mainly, drop outs and high error rates.  If the error rates are high enough then you'd probably find that latency (ping) was very variable, making gaming, streaming and voice or video conferencing difficult.  And if the connection is sufficiently error prone or erratic, it could affect speed as well.  But it doesn't follow that you'd have all of those symptoms.
Incidentally, if you're using a 15 dB attenuator and you're still seeing 8 dBmV power levels, then (a) you're getting rather close to the 10 dBmV limit for comfort so you might need a higher level of attenuation, and (b) there's a question as to whether your connection needs looking at to move it on to a different tap in the street cabinet rather than just applying industrial strength attenuation at the hub.  If all is working fine now, perhaps best to leave for the time being, but when some normality returns perhaps re-ask the question in these forums, and see if the VM staff can advise.
All wired connections are working fine and download and upload speeds are 350Mbps+ / 35Mbps.
I am having alot of problems with the WIFI. Some devices that worked fine on the Hub 2 are now losing internet access. They stay connected to WIFI but lose internet access saying "Connected with problems" or "Connected. No internet access"
Other devices are just really slow and take forever to load anything when connected to either the 2ghz or the 5ghz. I have disable all the "intelligent wifi and channel changing" but the same thing still happens.
An attenuator will cause your hub to raise its upstream power levels. Can you post your downstream and upstream levels and network logs.
Hub 5, TP-Link TL-SG108S 8-port gigabit switch, 360
My Broadband Ping - Roger's VM hub 5 broadband connection
