I am having an issue with the connection between my new super hub 4 and my Sky Q box dropping and then will not reconnect for a day or so, or connecting and then dropping and then connecting and then dropping again every few minutes.
I also recently got the message on my tv screen from a sky mini box which said the router is not issuing ip addresses.
I’ve done the usual numerous hub reboots and reset of the Sky box connection but the problem persists.
i see other people appear to have had similar issues, is there a solution that can be applied.
