  • 5
Message 1 of 8
Super Hub problems
We had a power cut on Saturday. The router restarted. However, It would no longer talk to my Apple Airport units. I called Apple and factory reset the units. A real pain. There is also a similar issue when I unplug my Mac from the network( hard wired to the router). It usually resolves with randomly restarting different but of equipment on the network. The old hub I'd had for 6 years didn't exhibit this problem. Any ideas to what the problem may be?
Below is the log from Saturday
07/12/2019 13:41:36
Warning!
Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/12/2019 13:47:43
critical
07/12/2019 14:08:12
Warning!
07/12/2019 14:27:7
critical
07/12/2019 19:17:27
Warning!
07/12/2019 20:25:48
critical
07/12/2019 20:31:29
Warning!
07/12/2019 20:51:4
critical
08/12/2019 12:03:31
Warning!
08/12/2019 12:08:31
critical
  • 15.75K
  • 1.65K
  • 2.69K
Message 2 of 8
Re: Super Hub problems
I take it you have got a new Hub3 - correct? If so what are the lights on it showing and doing? What exactly is the "similar issue" on the wired Mac?
I would do a pinhole reset of the Hub3 to factory settings first to see if that clears it. With the Hub "on" push in the pin on the back/side/bottom of the Hub with the end of a paperclip until you feel it at the “stop point” and hold it there firmly for a "timed" 60 seconds do NOT restart the Hub after that. Leave it 5' or so to stabilise and then your passwords/passphrase for both the Hub settings and the Wifi networks will revert to the two printed on the Hub sticker on its base/side/card.
Also, your Airport units... I assume these are Expresses and connecting by wifi - correct? You may want to try changing the settings in the Hub3 to disable channel optimisation and rename the SSID's of the 2.4 & 5 GHz wifi bands - so they are distinctly separated.
  • 7.56K
  • 597
  • 1.28K
Legend
Message 3 of 8
Those T3’s are often indicative of noise on your circuit. Please post you up/downstream stats.
  • 5
Message 4 of 8
Hi Tudor
As below:
Downstream
1402750000238256 qam25
21947500005.938256 qam8
32027500005.538256 qam9
4210750000537256 qam10
52187500004.838256 qam11
62267500004.537256 qam12
7234750000437256 qam13
82427500003.738256 qam14
92507500003.538256 qam15
102587500003.538256 qam16
112667500003.738256 qam17
122747500003.738256 qam18
132827500003.738256 qam19
142907500003.738256 qam20
152987500003.738256 qam21
163067500003.738256 qam22
173147500003.938256 qam23
183227500003.738256 qam24
19410750000238256 qam26
20418750000238256 qam27
21426750000238256 qam28
224347500001.938256 qam29
234427500001.938256 qam30
244507500001.538256 qam31
1Locked38.67030
2Locked38.61530
3Locked38.61550
4Locked37.61260
5Locked38.91020
6Locked37.61270
7Locked37.61901
8Locked38.62550
9Locked38.61550
10Locked38.61660
11Locked38.61060
12Locked38.61310
13Locked38.91170
14Locked38.61360
15Locked38.9930
16Locked38.9600
17Locked38.91250
18Locked38.61260
19Locked38.98240
20Locked38.610910
21Locked38.69070
22Locked38.614980
23Locked38.619540
24Locked38.932340
Upstream
pstream bonded channels
1325999893.975512064 qam29
2393999324.05512064 qam28
3462001414.075512064 qam27
4537002084.125512064 qam26
3ATDMA0000
4ATDMA0000
  • 7.56K
  • 597
  • 1.28K
Legend
Message 5 of 8
All values are within spec, although there does seem to be a wide range of power levels on the downstream. The Pre RS errors are corrected errors, but if you have power cycled or pin hole reset the hub recently they are a little on the high side. Again all I can suggest is a noisy circuit. You could try customer services to see if there are any problems in your immediate area or wait a couple of days for a VM staff member to get to your post.
  • 3.93K
  • 236
  • 429
Message 6 of 8
Hi SDM72,
Thank you for reaching out to us in our community, I am sorry to hear you are having issues with your super hub.
I have done some checks our end I cannot see any issues at all all levels are as they should be, no SNR issues, I hear that you have reset your apple products, have you done a pin reset on our hub, if you haven't this is something I would advised trying.
You will find the reset hole at the back of the router above the white cable,push a pin/ paper clip in the hole until you feel it pressing in, hold it in for a timed 1 minute, please do not turn the router off during or after this, allow to settle then try the connections again.
Kind regards
Paul.
  • 5
Message 7 of 8
Thanks for your input. Frankly, none of these issues happened on my old router. Listening to the voices in the know- it seems that if i buy another router put Virgin's on to Modem mode then there's a reasonable chance the problem may disappear. I really hope so. Life since Super HUb 3 has been less than ideal.
  • 15.75K
  • 1.65K
  • 2.69K
Message 8 of 8
I have the SH2 and have always had it in modem mode with an Airport Extreme and x2 Expresses and have never had any wifi issues issues - solid 220mbps down and 21 up on the Air/Pro/iPhones - when sat in the same room as one of the 3 devices on the 5GHz band. Some fall off in distant rooms but never less than 100mbps.
