ollyL
Message 1 of 7
Solid green WiFi light, flashing green light at base
Hi, I’m having trouble setting up my hub 3.0 and getting the same problem as other people on here, I have tried turning off and on again and also resetting multiple times.
Anything else I can try?
I need to be online ASAP due to work commitments.
  • 8.49K
  • 675
  • 1.52K
Message 2 of 7
Re: Solid green WiFi light, flashing green light at base
If it’s a new installation, have you phoned up to get the hub activated?
ollyL
Message 3 of 7
Hi Tudor,
Yeah, I did the text activation and also followed up with a call, but still had the same problems.
DavidJWalker
  • 716
  • 52
  • 109
Rising star
Message 4 of 7
ring up again to see if its acticed on the account
before that pin reset the router to see if it can get online but sometimes they forget to push the update out at the same time when they send out the signal
My Broadband Ping - Virgin Media 350MB
Using Ultimate Oomph bundle
Just another VM user trying to help out so my answers may be wrong. If you do like my answer please mark it as helpful; it may help others
ollyL
Message 5 of 7
Thanks, David. I'll give that a go.
  • 24.07K
  • 2.54K
  • 4.37K
Message 6 of 7
If there is still no connection and they insist it is activated (check that the serial number they have activated is the same as that on your Hub!).
then you will need to swap to a tech install. When VM send out quick start packs they never test the network connection - they just know that there was an active service at your location in the past. This may have been damaged of disconnected for some reason. A tech will check it all out
Alex_RM
  • 4.54K
  • 260
  • 345
Message 7 of 7
Hi ollyL,
Thanks for posting and welcome to our community 🙂
I'm sorry to hear you've had some trouble setting up the new hub.
I've been able to locate your account using your forum details and can see you've been able to speak with an agent to arrange an engineer.
If you do need anything else please let us know.
Alex_Rm
