DHale
Small Booster not Connecting to Hub
I have just received my boosters through the post and the little booster will not pair with the hub.  The pairing light keeps flashing red.  I pressed Sync and it turned green and started flashing but then it turned back to red and kept flashing.  Any suggestions please?
jb66
  • 12.27K
  • 911
  • 1.78K
Re: Small Booster not Connecting to Hub
Try pressing sync on both of them so they both flash at the same time
Z92
  • 2.45K
  • 202
  • 390
Problem sorter
You are not pairing them with the hub you are pairing them with each other. They are normally physically connected to the hub by a cable.
DHale
I was sent a quick start link which I used instead and everything connected perfectly for about 2-3 minutes.  Ever since then I can't get wifi anywhere in the house unless I turn the boosters off.  Any ideas welcome.
