Should I get a Hub 4 on my current plan?
cendricli
Currently have a Hub 3 that I've had since mid-2019 with Volt M125 Fibre Broadband. I asked for a new ethernet cable which they sent with a new hub 4, but I'm not sure if I need it. Would I notice a difference/improvement?
2 REPLIES 2
No, the Hubs 3 and 4 are suitable for M125.  I would doubt if you will notice any difference. If the Hub 3 is working, I would leave it well alone.
John_GS
Hi @cendricli
Apologies for any confusion. Normally if any equipment is sent, it auto-activates within 12 hours so you'll need to switch over to the new router.
Best wishes.
John_GS
