Hey all,
As per the title, my neighbour seems to be using the same cable that runs under my drive. While I do understand this is fine and wont affect my service, it does make me wonder, is this normal and correct install?
The reason I'm asking is that the cable I 'think' runs under my drive, yet it may also go under some bushes that i want removed. My concern is hitting the cable and bringing my neighbours internet down (Even though i care about bringing mine down, I'd rather bring down mine than theirs!) It also means that if anything happens to the box on my house both our connections goes down. This happened earlier in the year, VM came out and did something to my neighbours connection and took mine down too, not 100% sure what they were doing but I think they disconnected the link from the wallbox.
Ideally, shouldn't we both have our own cable that taps off the cable under the street? The wall box on my house also looks quite worse for wear and doesn't shut properly / is faulty - is this an issue and would rain etc damage any cables / splitters?
I moved in last year so the service was already run when I moved in so not sure how long its been run into the property or when this was done.
