on 10-09-2022 11:38
Right cable seems to have been cut, is this possibly the issue resulting in no internet?
on 10-09-2022 12:14
inside look
10-09-2022 15:07 - edited 10-09-2022 15:09
Connect your wire to the black wire. You may need an adaptor from B&Q .
https://www.diy.com/departments/slx-f-type-satellite-cable-coupler/5028422001905_BQ.prd
on 10-09-2022 15:16
@Adduxi wrote:Connect your wire to the black wire. You may need an adaptor from B&Q .
that may work but why not connect the hub to the black wire first - if it works go to step 2 and get the connector
but thats a powered splitter so it needs a power supply which is what the cut wire was connected to so the question is why is it there
10-09-2022 16:10 - edited 10-09-2022 16:12
Perhaps a missing power connection to a fibre media converter outside?
Mundashunda, is your service from VM over fibre or coax cable? You might get an idea from the last pic's on this page
which show two types of outside VM box. LHS is for coax, RHS is bigger for fibre equipment. I believe the fibre equipment needs power from inside the house which is also fed on the coax cable to the outside unit. As per this image
https://richardglover.co.uk/wp-content/uploads/2017/07/IMAG0971-e1501113493339.jpg
10-09-2022 16:45 - edited 10-09-2022 16:49
Might not be fibre. It might simply be that the OP is at the cabinet operating limit & has an external HDU to drive other outlets around the house. If this is the case only one of those outlets will work without the power supply connected. It will depend what outlet the former occupant nominated when it was installed.
on 10-09-2022 16:55
So next question for Mundashunda, what is the black cable going through the wall connected to?
on 10-09-2022 18:45
@goslow wrote:So next question for Mundashunda, what is the black cable going through the wall connected to?
Most likely an external HDU. As per my last post, the OP will have to check any other outlets they have, as one of them should work without power.
on 12-09-2022 19:01
Hey Mundashunda, thanks for posting on our help forum.
Sorry to see you've had issues with the installation of your new hub from us, could you please let us know if you've managed to get this done since you last posted here?
Also, has the advice from our helpful forum members helped with this?
Please, tell us where you are with this and if you still need any help, happy to assist you further.
