westcmc
Message 1 of 5
Self installation problem
I recently received my new home hub however my new property doesn't have the isolator cable box to plug it in to. I have two cables coming out of the wall but no luck so far with those. I keep on receiving the flashing green wifi light and green bar at the bottom of the hub. Do I need an engineer to come out and fix this for me?
Anonymous
Not applicable
Message 2 of 5
Re: Self installation problem
It may be a case of having to activate the HUB.
Could you post a picture of the cables you have?
westcmc
Message 3 of 5
Thanks for your reply!
I have just checked and the cables run outside through the wall up to a dish but they aren't connected so I'm not sure a photo will be necessary?
Will I need an engineer visit, and if so how do I arrange that?
Thanks in advance.
Anonymous
Not applicable
Message 4 of 5
Thanks in advance.
Sounds like Sky coax cables.
One of the VM team should reply to your thread.
Emma_C
  • 8.28K
  • 512
  • 559
Message 5 of 5
Hi Westcmc,
Sorry that the property wasn't set up for a self install and for the delay in getting back in touch, we have been a lot busier than usual.
I have had a look at things using the details you provided when joining the community and I can see that you've since been able to speak to the team to get everything set up.
I hope you're enjoying the services but if you do have any further issues please let us know 🙂
Emma_C - Forum Team
