Message 1 of 5
Self installation. White base light no WiFi light
Hey,
I’m doing self installation because of covid.
I have Hub3 and I have followed instructions but at no point have I seen the WiFi light flashing or light up in any way. The base light, internet connection arrows and phone light all flashed and did their thing.
Currently I have a solid white base light. I have tried rebooting and testing all cables are in firmly.
Does something need activated?
  • 15.35K
  • 1.7K
  • 3.51K
Message 2 of 5
Re: Self installation. White base light no WiFi light
Is the WiFi working?
If it is don’t worry too much about it for the time being.
Virgin BB TV Landline. Freeview/Freesat HD, Virgin Mobile, Tesco Mobile. Cable customer since 1993
Message 3 of 5
It is not working
  • 65
  • 14
  • 19
Message 4 of 5
Hello
Please private message me your account number, area code, address and cm mac on the base of the router and i will get this sorted
If I've helped in any way, please give me Kudos and mark my response as a helpful answer!
Fancy £50 off your bill? Ask me how and you might just get it!
I am a serving Field Technician at Virgin however all responses on here are based on my experiences in the field alone and my own equipment at home and should be taken as such
  • 353
  • 62
  • 77
Message 5 of 5
Please send me a private message, not reply or quick reply, with your account number, area code/ postcode and the CM MAC of the modem and I'll try and get it sorted for you.
Rob
