richard49
  • 178
  • 6
Up to speed
Message 1 of 10
Reset Network Problem
I was having slow internet connection on my Windows 10 laptop so (unfortunately) reset my network.
I now have no VM network showing up under 'Network' and can't find a way to re-install it.
Might you be able to advise what to do as I can't find anything on the Virgin website that helps?
Any advice would be helpful.
Tags (2)
goslow
  • 5.38K
  • 728
  • 1.94K
Superstar
Message 2 of 10
Re: Reset Network Problem
What do you mean when you say no VM network showing up under 'Network' ?
If you are trying to make a wi-fi connection and can see the hub's SSID, follow the Windows 10 video here
https://www.virginmedia.com/help/broadband/connect-devices
If you can no longer see the VM SSID, this may be because the W10 network reset has reinstalled your network card drivers.
  • 6.79K
  • 591
  • 1.78K
Message 3 of 10
Or did you reset the networking on your laptop and have disabled the wifi on the laptop ?
richard49
  • 178
  • 6
Up to speed
Message 4 of 10
Sorry to have taken a long time to get back to you.
As I had the problem mentioned I thought that I'd restore the computer to an earlier restore date but that went south very quickly....
I ended up in a never ending loop and ended up restoreing the laptop to the factory settings which after re-instaiing windows and all of the updates associated with it it took just over a full day to get back to where I was started; a working laptop that connects tot he Internet.
I didn't mind doing it as I think that after a few years of use it does the laptop good to have a 'clearout'.
Thanks again everyone who took the time to respond, it is appreciated.
  • 6.79K
  • 591
  • 1.78K
Message 5 of 10
Glad you got it sorted and it's all working.
Agree with the refresh of Windows!  🙂
  • 13.85K
  • 1.07K
  • 2.81K
Message 6 of 10
With lots of Windows problems I gave up on Microsoft 2 years ago all for the better.
goslow
  • 5.38K
  • 728
  • 1.94K
Superstar
Message 7 of 10
<snip>
Depending on the specs of your laptop, you could have a look at some of the free backup/imaging programs to help restore a laptop back to a known condition very quickly.
I have used 'Macrium Reflect Free' for a long time (but sadly no longer free from Jan 2024)
and am now evaluating 'Paragon Backup & Recovery Community Edition' (currently free) as a replacement
With a USB3 connection on the laptop, and backing up to a USB3 external hard drive, the entire laptop can be restored to a basic build of Windows from an image in about 5 to 10 minutes (via a bootable USB pen drive).
I often make an image before any major computer hardware/software changes so that if the changes go wrong I can go back to the previous setup very quickly.
richard49
  • 178
  • 6
Up to speed
Message 8 of 10
I'll make a not of that for making an image before any major computer hardware/software changes
  • 6.79K
  • 591
  • 1.78K
Message 9 of 10
@goslow  and @richard49
I have been using this for years across different kit and it works great. I even keep images on a USB drive for relatives kit. It’s also free…..
https://www.veeam.com/agent-for-windows-community-edition.html
goslow
  • 5.38K
  • 728
  • 1.94K
Superstar
Message 10 of 10
Thanks, will give that a go alongside Paragon as a replacement for Macrium.
