on 07-12-2021 22:02
How do I request a replacement lid for our brown box? It's been loose since we moved in last year but it's either blown off or been removed so now the wires are exposed.
Thank you
Answered! Go to Answer
on 18-12-2021 09:46
Hi Borisbear
Thanks for the image
We can get this booked in to be fixed for you
I will need to send you a private message to pass security
If you can check the purple envelope top right of your screen that would be great
Gareth_L
on 07-12-2021 22:44
Call Customer Services on 0345 454 1111/150 if you have a VM landline or wait a day or two for a VM staff member to get to your post
on 10-12-2021 10:47
Hello @Borisbear,
Welcome! Thanks for posting.
Please can you post a photo of the box? Then I can move forward 🙂
Many thanks,
on 15-12-2021 12:17
Hi I've tried sending a photo to you but it says it's too big. It's a standard brown box but the lid is missing now
Thank you
on 15-12-2021 14:58
on 15-12-2021 16:17
on 15-12-2021 16:18
Thank you so much, I didnt know how to do it but googled what you put, got an app and voila 😁😁😁
on 18-12-2021 09:46
Hi Borisbear
Gareth_L
