Replacement coax cable required
Hello everyone,
Just wondering if anyone can help me as I have been unable to get in contact with anyone on the virgin media help line today. Today I got my broadband set delivered and opened the box to find a damaged coax cable. I have looked across the forum and many suggest not buying one off brand so was wondering how I could get them to send me a replacement as they don’t seem to be answering the help line.
thanks in advance.
  • 14.84K
  • 1.17K
  • 3.47K
Re: Replacement coax cable required
you are correct that purchased replacements should not be used - add to that the cable is also diffent to a straight coax on in that it has an isolator in in - lets see if i can get VM here to sort it
____________________
Tony
Thanks that would be really helpful I’m not sure how to contact them other than the one helpline they have
  • 2.55K
  • 150
  • 324
Hi conrawlin, thanks for getting in touch.
Apologies for the damaged cable you received. We can arrange a replacement though depending on availability a tech-visit may be a better option in the interest of getting you up & running asap.
I'll get in touch via PM to confirm a few details & will look forward to hearing back from you.
Tom
