SueP81
Replacement adapter cable
I have a virgin hub 3. The ac adapter cable has snapped. I’ve asked Virgin for a replacement but I could do with getting one more quickly. Can I get one on Amazon and if so what’s  the full spec I should look for please - this cable came with a blue sticker “plug me into your hub”
thanks
-tony-
  • 18.98K
  • 1.44K
  • 3.65K
Re: Replacement adapter cable
the spec and size is likely on the cable or adaptor - they are not special in that as long as you get the correct spec it will work but you be better to get it from VM - that way you are 100% sure its correct
____________________
Tony.
Sacked VIP
carl_pearce
  • 1.44K
  • 93
  • 317
Knows their stuff
thanks
https://myvolts.co.uk/product/34960/UK_12V_Power_Adaptor_for_the_Virgin-Media_Super-Hub-3.0_Router_b...
https://www.amazon.co.uk/Replacement-Adapter-Power-Supply-Virgin/dp/B088N6RT8X/ref=sr_1_3?crid=U9PMR...
https://www.acadaptorsrus.co.uk/12v-3a-ac-adapter-fra036-s12-4-power-supply-c13-c14-with-uk-plug-lea...
SueP81
Brilliant, thank you
thanks for taking the time to help
