Chris_W1
  • 4.07K
  • 185
  • 256
Message 31 of 47
Re: Removal of outside box and cabling
Hi rchotai, we are glad to see that this is on the way to becoming resolved. Please let us know if you need anything - Chris
helen_pope
Message 32 of 47
Good afternoon,
I also have the problem of a brown box on the wall of our property and cables running in a green tube through our garden. We do not have Virgin Media at our property at the moment.
The cables are directly beneath the paving flags in our garden and we want to redo the paving properly by excavating out slightly to lay hardcore. We cannot do this where the cables are because they are so close to the surface.
I don't want to start cutting cables in case there is a health and safety risk.
Please can someone advise?
Akua_A
  • 1.45K
  • 33
  • 103
Message 33 of 47
Hi @helen_pope
Welcome to our community and thank you for your first post.
We don't usually come out to remove cables unless there is a health and safety risk. However in this case we may have to look into getting these cables reburied or removed for you.
 I will need some information from you to enquire about this with our area field team so I have sent you a private message. Just click on the little plum envelope at the top right hand side of the page to access your inbox.
Akua_A
Akua_A
  • 1.45K
  • 33
  • 103
Message 34 of 47
Thank you for providing the relevant information @helen_pope.
I will pass this onto our Area field Manager and will get back to you as soon as possible with the outcome.
Akua_A
Owain2
Message 35 of 47
How do we going about arranging for unused virgin media cables to be removed from our garden? They are currently running above ground through our front garden
Owain
Travis_M
  • 1.23K
  • 45
  • 102
Message 36 of 47
Hi @Owain2
Welcome to the community forum and thanks for posting!
I've emailed the area field manager to see what we can do for you and i'll get back to you as soon as possible once I hear back.
Travis_M
Owain2
Message 37 of 47
Hi Travis,
Thanks for coming back to me. Could you put me in touch with the area manger directly please. I haven't confirmed any location detail as yet so would like to confirm who has been contacted.
If you could drop me a private message that would be great
thanks
Owain
Travis_M
  • 1.23K
  • 45
  • 102
Message 38 of 47
Hi @Owain2
Unfortunately I wouldn't be able to put you in direct contact with the area field manager, the response I received is that we will not be able to remove any of our cables at the moment.
Travis_M
Owain2
Message 39 of 47
Hi Travis,
To confirm I can cut and removed cables where they enter our garden from the street and this is not an issue for Virgin media?
Owain
MSdR
Settling in
Message 40 of 47
Hello,
I have a somewhat similar issue. I had VM installed when I moved into my flat 2,5 years ago. The landlord now wants me to remove the cables when I move out, both internally and externally. I understand you don't come out to remove cables that are not a hazard, but can you advise on who I may contact to have them removed without damaging anything?
Many thanks!
Melissa
