theres no current or voltage that will do you or anyone else any harm - its data thats coming down it pretty much the same as an aerial cable - but as said give them chance - a VM bod will get to the thread and arrange via an area field manager [AFM] to get it sorted
thats when it may go pear shaped - AFM's come from helpful to not so - a tech may turn up and sort it or your request may be forgotten and nothing happen
so give them a reasonable time - a few weeks and then decide - take no notice of those who say its a utility and cannot be removed - total rubbish - but if VM remove it the property is likely to be black listed so an install cannot happen in the future
if you dont want to be bothered with all of that - a pair of wire cutters is all you need
____________________
Tony.
Sacked VIP
