grovepark77
Message 1 of 23
Removal of old external cabling and box
Not a Virgin customer but I have an old cable box without a cover and a number of wires coming out of it going to various places on the front of my house. All extremely unsightly - assume from other threads on here that I’d be wasting my time trying to get VM to remove it all and can do so myself?
nodrogd
  • 17.5K
  • 2.05K
  • 4.37K
Message 2 of 23
Re: Removal of old external cabling and box
You can take out everything back to the external box. VM will provide you with a cap for the incoming cabinet drop, but they will not remove the drop unless it poses a safety hazard. As with BT Openreach lines, these are classed as a utility feed to the property, so are left in for possible future use.
VM BB TV Landline. Vonage 2nd line. Freeview/Freesat HD, ASDA/Tesco PAYG Mobile. Customer since 1993
Akua_A
  • 2.9K
  • 71
  • 188
Message 3 of 23
Hi @grovepark77,
Welcome to our community forums and thank you for your first post.
Thank you for letting us know. We do not usually come out to remove cable unless there is a health and safety risk. Are the cables loose/ exposed? Are you able to provide a picture?
Akua_A
grovepark77
Message 4 of 23
Hi, thanks for your response. No immediate H&S issue but the cable will need capping at ground level. Is that something you can arrange? Picture below.
Akua_A
  • 2.9K
  • 71
  • 188
Message 5 of 23
Thanks for providing that @grovepark77.
I can make an enquiry with our field team to see if it is possible to do so. I have sent you a private message regarding this. Please look out for the purple envelope on the top right hand corner and get back to me when you can.
Akua_A
slarosa
Message 6 of 23
i have the same problem,
Cables have been left loose and exposed and it's a health and safety risk.
Could you please come and remove them?
Thank you
Salvo
Beth_G
  • 4.7K
  • 269
  • 487
Message 7 of 23
Hi Salvo,
I'm sorry to see that the cabling has been left in this way - can you please confirm if you are/are not an active Virgin Media customer?
Many thanks,
Beth
Beth
slarosa
Message 8 of 23
Hi there,
I am not an active virgin media customer, I used to have VM TV and Internet some years ago,
Salvo
  • 5.62K
  • 462
  • 1.42K
Message 9 of 23
@grovepark77 wrote:
Hi, thanks for your response. No immediate H&S issue but the cable will need capping at ground level. Is that something you can arrange? <snip>
You can unscrew the cable (coming from the ground in your picture) from the splitter and cap it with a terminator, such as below;
electrosmart Pack of 10 75 Ohm F Plug Type Terminators: Amazon.co.uk: Electronics
Once it's capped, all other cables and splitter can be removed.
Beth_G
  • 4.7K
  • 269
  • 487
Message 10 of 23
Hi Salvo,
If you're unable to do the above as Adduxi has suggested, I'll pop you over a PM so I can take some details 🙂
Beth
Beth
