hfwarner
  • 6
Message 1 of 18
Removal of cable and box
i have recently moved into a house where the previous owner had virgin broadband installed. The cabling was installed inside a green plastic tubing which stretches across the front garden and isn’t buried. In fact we can’t bury it as it goes across paving and a wall but is a massive trip risk.
We won’t be using virgin media and would like this cable and the box inside the house removed please. How do I arrange?
thanks
Tags (2)
gary_dexter
  • 32.63K
  • 2.02K
  • 4.47K
Message 2 of 18
Re: Removal of cable and box
It won’t be removed. It’s classed as a utility
crany
  • 192
  • 15
  • 36
Superfast
Message 3 of 18
you should post photos if its a hazard virgin may come out and tidy it up
hfwarner
  • 6
Message 4 of 18
photo of the cable. It also stretches across the path at the front. So dangerous
hfwarner
  • 6
Message 5 of 18
Utilities are essential. This isn’t and I don’t use it
Zak_M
  • 6.12K
  • 315
  • 545
Message 6 of 18
Good morning @hfwarner
Welcome to the forums and thank you for taking the time to post.
I am sorry to hear that you have had some issues with the cables not being buried.
We wouldn't be able to remove the boxes from inside the property however if you can provide us with some photos we would be able to arrange to get these buried.
Kind regards,
Zak_M
hfwarner
  • 6
Message 7 of 18
Thanks. I’ve just posted a photo. As I explained though it won’t be possible to bury it as it stretches over a brick wall and also a path in front of the wall.
id really like it removed please
  • 6.08K
  • 511
  • 1.57K
Message 8 of 18
One point to bear in mind, is if this is removed back to the footpath, VM will mark the property as "unusable" for any future customers. You should be able to remove any internal wall points and cables, providing the cable from the outside is properly terminated.  Otherwise noise ingress will affect all the VM users on the same street cabinet.
hfwarner
  • 6
Message 9 of 18
Hi there
thank you for this. What do you mean by ‘properly terminated’ and how would I know unless they come out and do this as we’ve requested?
-tony-
  • 18.98K
  • 1.44K
  • 3.65K
Message 10 of 18
thats awful how in hells name did anybody think that was acceptable - VM will get to the thread and the best they can do on here is flag it to the area field manager [AFM] - that can have mixed results - some will get a tech out and get it sorted - others will ignore all requests and hope you give up
its not a utility - not legally whatever the misinformed say on here - the previous owner ordered it and by default gave permission for that travesty - why [as i started] is a good question - as the new owher permissions granted from a previous owner are not binding on you - so you have options
1 - wait for VM to offer to get an AFM involved if they have not already
2 - assuming they do arrange for said AFM be clear what you want and in what time scale
3 - just get on and remove -  it as is offered as a solution by staff here and AFM's in the field
if you choose 3 you have no responsibility to terminate the connection correctly simply cut it at your boundary and remove any internal or external boxes but as said above if you or others in the future wanted a VM connection you are likely to find the property blacklisted
if you get a helful AFM things will likely happen as you want/hope - if you get one at the other end of the scale you will get lots of promises and input from staff here and go round in circles getting nowhere
____________________
Tony.
Ex VIP
