oni41
  • 7
Message 1 of 13
Red light on hub 3 wont go out
The red light will not go out on my hub 3, the hub is in a well ventilated area with nothing round it and stood up correctly.
I left it turned off for a few hours and still the red light stays on the moment it is switched on,.
There appears no option with technical support to replace faulty hardware.
Z92
  • 2.46K
  • 203
  • 392
Problem sorter
Message 2 of 13
Re: Red light on hub 3 wont go out
Is the hub in modem mode or router mode?
Does your connection otherwise work OK ?
oni41
  • 7
Message 3 of 13
Thanks for answering my question
Its in Modem mode and the internet is up and down, tried it in router mode with the same internet issues.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 4 of 13
In Modem Mode the Power Light is magenta.
A red Power Light indicates an overheat.
If nothing is showing try phoning 0800 561 0061, this will tell you of more local issues that may be affecting your district. Be aware that it isn't a manned line.
Go round all the accessible internal and external co-ax connections and ensure that they are finger tight.
If everything above is OK we need do some more troubleshooting; to start with …
Then
Can you please
  • 23.94K
  • 2.53K
  • 4.34K
Message 5 of 13
As Mike has suggested, put it back into "Router" mode - if the light stays red you have a problem if it changes then its ok.
oni41
  • 7
Message 6 of 13
Thanks for the reply,  i will run the test and send the results.
Status for my area is showing no issues also modem is has been red for a week, just havent been able to get in touch with virgin to see if they can swap the box.
oni41
  • 7
Message 7 of 13
Hi thanks for the reply, i have replied and said tried that and still have the issue.
oni41
  • 7
Message 8 of 13
Downstream
1
267000000
-0.7
40
256 qam
17
2
139000000
1.5
43
256 qam
1
3
147000000
0.9
40
256 qam
2
4
155000000
1.4
43
256 qam
3
5
163000000
1
43
256 qam
4
6
171000000
0.7
40
256 qam
5
7
179000000
0.7
43
256 qam
6
8
187000000
0.7
40
256 qam
7
9
195000000
0.5
40
256 qam
8
10
203000000
0.2
43
256 qam
9
11
211000000
0
40
256 qam
10
12
219000000
0
40
256 qam
11
13
227000000
-0.2
40
256 qam
12
14
235000000
-0.4
40
256 qam
13
15
243000000
-0.7
40
256 qam
14
16
251000000
-0.9
40
256 qam
15
17
259000000
-0.5
40
256 qam
16
18
275000000
-1
40
256 qam
18
19
283000000
-0.9
40
256 qam
19
20
291000000
-1.4
40
256 qam
20
21
299000000
-1
40
256 qam
21
22
307000000
-1.4
40
256 qam
22
23
315000000
-2.2
40
256 qam
23
24
323000000
-1.5
40
256 qam
24
1
Locked
40.9
106
70
2
Locked
43.3
2286
4710
3
Locked
40.3
2123
5220
4
Locked
43.3
1153
6168
5
Locked
43.3
3546
2546
6
Locked
40.9
1899
5588
7
Locked
43.3
3522
2727
8
Locked
40.3
3185
393
9
Locked
40.9
1892
369
10
Locked
43.3
817
376
11
Locked
40.9
970
239
12
Locked
40.3
3916
516
13
Locked
40.9
468
178
14
Locked
40.9
197
188
15
Locked
40.9
126
119
16
Locked
40.3
113
146
17
Locked
40.9
111
88
18
Locked
40.3
88
66
19
Locked
40.9
136
71
20
Locked
40.3
6488
182
21
Locked
40.9
5519
91
22
Locked
40.3
213
91
23
Locked
40.3
2919
72
24
Locked
40.3
5539
220
Upstream
1
32599988
4.95
5120
64 qam
5
2
39400000
4.95
5120
64 qam
4
3
46200043
5.1
5120
64 qam
3
4
53700009
5.1
5120
64 qam
2
1
ATDMA
0
0
0
0
2
ATDMA
0
0
0
0
3
ATDMA
0
0
0
0
4
ATDMA
0
0
0
0
oni41
  • 7
Message 9 of 13
TimePriorityDescription29/10/2020 11:42:3Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;28/10/2020 17:00:14noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt062-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;28/10/2020 17:00:14ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;28/10/2020 14:34:15Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;26/10/2020 19:50:12criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;26/10/2020 03:53:47noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt062-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;26/10/2020 03:53:47ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;26/10/2020 02:36:31criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;23/10/2020 13:06:37Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;22/10/2020 22:15:10criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;22/10/2020 16:46:29noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt062-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;22/10/2020 16:46:29ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;19/10/2020 07:29:13Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;19/10/2020 02:01:7noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt062-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;19/10/2020 02:01:7ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;19/10/2020 01:30:42criticalREG RSP not received;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;19/10/2020 01:30:42ErrorT6 Timeout and retries exceeded;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;19/10/2020 01:30:10criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;19/10/2020 01:29:56Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;19/10/2020 01:28:23criticalReceived Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
oni41
  • 7
Message 10 of 13
