on 10-04-2023 19:33
Have red light light since this afternoon.
Was trying to change hub from router to Modem.
Hub has been in same place out of the light for a number of years so overheating isn’t the issue.
Have tried all the usual things to make it work: reset, unplug etc but none work.
Think i need a new hub or engineer visit or both.
on 10-04-2023 23:53
The light in modem mode can look red to some. Officially it’s magenta but people see colours differently.
on 11-04-2023 11:08
You are correct. Looking at the light from a different angle it is magenta.
Thanks for the reply.
