Re: Cost of moving cable entry point?
Soctty123
My issue is that I've moved my hub from my kitchen into my living room and only need to shorten my cable. Would this still be £99?
1 ACCEPTED SOLUTION
Accepted Solutions
Hi @Soctty123
This would be classed as a non fault callout. The cost has now been reduced to a more affordable £25.
You can either call  150 from a Virgin landline or mobile, or 0345 454 1111, option 2 (Faults
When calling Faults you will hear the automated response asking you to press 1 for the link to online support etc
Ignore all the options and don't press any buttons then you should be placed into a queue and an agent should pick up the phone and book the tech for you.
Or wait a day or two and a member of the Forum Team should pick this up for you and arrange a tech visit.
Dave
The do's and don'ts.
16 REPLIES 16
Hi @Soctty123
Dave
Thanks so much for the info.
Hi Soctty123,
Thank you for your post. As newapollo has advised it would be £25 for the visit.
If you do still need assistance with getting this booked in, please let us know and we can get that booked in for you.
^Martin
Yes, that would be great thanks.
No problem @Soctty123
I'll pop you a PM now so we can arrange this.
Please keep an eye out for the purple envelope in the top right corner of your screen alerting you to a new message.
Thank you.
Thanks Ashleigh. Aplogies - I think I called you Ash in my message.
No problem @Soctty123 and Ash or Ashleigh are fine! 🙂
As we have confirmed via the PM this is all booked for you now and please do let us know how the appointment goes!
Thank you again for your time!
Can someone on the Forum Team organize the movement of my cable point please?
Hi wodewick,
Thank you for reaching out to us in our community and welcome, I will be more than happy to help you with a relocation, this will be a one off £25 charge, I will send you an invite into a private chat, once received please click on the purple envelope to accept.
Paul.
