  • 9
Random loss / slow of Wifi - Multi Devices - Both 5ghz and 2.4 bands
Hey so we have  been experiencing some pretty random WiFi drop over thew last few weeks.
Started (i think)with a service drop out a couple weeks back and the connection just been what would call wobbly since , we get general disconnects and phones say we"authorisation on network required" and TV becomes unable to playback or even load Netflix library sometimes.
rebooting the router usually resolves it for a time but its becoming annoying and i wondered if someone more knowledgeable then myself would take a look at the logs.
Thanks kindly
  • 9
Re: Random loss / slow of Wifi - Multi Devices - Both 5ghz and 2.4 bands
12030000002.237256 qam9
22110000002.437256 qam10
3219000000237256 qam11
42270000002.237256 qam12
52350000002.237256 qam13
62430000002.237256 qam14
7251000000237256 qam15
8259000000237256 qam16
9267000000237256 qam17
10275000000237256 qam18
112830000002.238256 qam19
122910000002.538256 qam20
132990000003.237256 qam21
14307000000338256 qam22
153150000003.238256 qam23
163230000003.238256 qam24
174270000003.538256 qam25
184350000003.738256 qam26
194430000003.738256 qam27
20451000000438256 qam28
214590000004.338256 qam29
22467000000438256 qam30
234750000004.138256 qam31
24483000000438256 qam32
1Locked37.6780
2Locked37.3450
3Locked37.6990
4Locked37.6720
5Locked37.6860
6Locked37.6920
7Locked37.61050
8Locked37.61160
9Locked37.6740
10Locked37.6800
11Locked38.91510
12Locked38.6790
13Locked37.61180
14Locked38.9760
15Locked38.9480
16Locked38.6590
17Locked38.9620
18Locked38.6660
19Locked38.9640
20Locked38.9590
21Locked38.9450
22Locked38.6760
23Locked38.9470
24Locked38.9680
1326000004.525512064 qam3
2462000004.525512064 qam1
3257999404.525512064 qam4
4393999614.475512064 qam2
3ATDMA0000
4ATDMA0000
04/05/2020 03:48:27criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
03/05/2020 09:15:23noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
26/04/2020 03:54:43criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/04/2020 22:00:57ErrorDHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/04/2020 06:15:53ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/04/2020 04:02:49criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/04/2020 14:30:54ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
19/04/2020 11:31:45criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
17/04/2020 21:33:26ErrorDHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
17/04/2020 01:38:31ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/04/2020 12:05:27criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/04/2020 00:37:23ErrorDHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/04/2020 20:43:1ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/04/2020 17:07:59criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/04/2020 09:00:6ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/04/2020 22:16:52criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/04/2020 17:22:53ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
09/04/2020 01:55:13criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/04/2020 14:31:31ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
03/04/2020 02:45:49criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
  • 3.56K
  • 196
  • 544
Community elder
There's nothing wrong with the signal levels, but they only show the connection to the Hub. They can't show what's happening to the WiFi.
What speeds do you get with an ethernet connection?
  • 9
Ethernet always pushes 212Mb (ish) easy and from my phone on 5 GHz its also hitting around there. its just when it drops we all lose connection and when / if it comes back on its usually crawling slow until we reboot the router again. I know that WiFi is unreliable at best but these issues only started after a issue in my area so im suspicious.
