Darciep96
Message 1 of 11
Quick start not working hub 3!
Hello!
wondering if someone can advise, we have two cables coming in through the wall from a virgin media box, we have just moved in previous tenants had VM too. The box has just been flashing green ever since I plugged it in yesterday morning!
can someone advise if the wiring in the box outside (pic attached) looks correct and tell me where to plug these cables coming through the wall into?? Earliest I can get an engineer is Wednesday so would like to try and resolve myself!!!! 🙂
thanks
Darcy
-tony-
  • 18.72K
  • 1.43K
  • 4.63K
Message 2 of 11
Re: Quick start not working hub 3!
pictures really are not clear in what they say - the twin internal cables - are they seperate or do they a twin cable - if they become one twin cable they are likely to be sky theres also a splitter above the skirting board - thats more likely to be the VM connection
____________________
Tony
Darciep96
Message 3 of 11
Hi Tony
perfect thanks, the splitter above the skirting I have now plugged into and the hub seems to have more lights showing now both WiFi and internet are flashing I’m assuming it’s setting itself up now. On the splitter there’s a red marked one and a white marked one, is it best to plug into the red one I’m assuming?
thanks
Darcy
Buffer6
  • 13.09K
  • 94
  • 679
Hero
Message 4 of 11
Did you phone up to get the Hub activated?
  • 5.62K
  • 462
  • 1.42K
Message 5 of 11
AFAIR usually the splitters are marked FM and TV, and the norm is to plug into the FM side.  However if the Hub is updating it all seems okay.  Post your power levels and network log once the Hub has finally settled.  We can comment further.
-tony-
  • 18.72K
  • 1.43K
  • 4.63K
Message 6 of 11
@Darciep96 wrote:
Hi Tony
thanks
Darcy
not sure on which one to use - you can try both obviously - the base light should go white and all other lights go out - you may need to activate the hub - 0800 953 9500 some come pre activated others not
you can remove the splitter and connect the cable direct to the hub - if its not long enough you need one of these
https://www.diy.com/departments/tristar-data-cable-coupler/571706_BQ.prd
Tony
Buffer6
  • 13.09K
  • 94
  • 679
Hero
Message 7 of 11
A splitter must be terminated on unused ports, I think one port goes to VM TV box and the other to the Hub
nodrogd
  • 17.49K
  • 2.05K
  • 4.37K
Message 8 of 11
Looks like a reverse feed HDU to me, although there is nothing in the outside box for it to drive. Also internal kit usually is metal, not plastic. I would say the red socket is the power coax that goes to a mains adapter. The white will be the amplified output.
PS. Splitter diplexers that have a TV & FM outlet only pass the FM frequencies to the FM outlet, which is now disused. The TV outlet passes the frequencies required for both Broadband & TV.
VM BB TV Landline. Vonage 2nd line. Freeview/Freesat HD, ASDA/Tesco PAYG Mobile. Customer since 1993
  • 5.62K
  • 462
  • 1.42K
Message 9 of 11
@nodrogd wrote:
<snip>   PS. Splitter diplexers that have a TV & FM outlet only pass the FM frequencies to the FM outlet, which is now disused. The TV outlet passes the frequencies required for both Broadband & TV.
One to remember!  Every day is a school day 🙂
Darciep96
Message 10 of 11
I now have the hub working and have internet! 🙂
however when we plugged our 360 tv box in the broadband goes down and doesn’t come back up until we disconnect the TV box? Anyone come across this before? I think I need to call out an engineer
Tags (4)
