Message 1 of 8
Quick Installation help required (with pictures inside)
Hello Forum - could someone please help?
I have a cable coming from a wall socket and the virgin media isolator cable, but they won't fit.
Could someone kindly advise if could I get a dual ended connector online to connect these two cables?
Thanks a million!
Pic 1 2   - cable from the wall socket
Pic 3,4 - virgin media isolator cable
Pic 5- wall socket
pic1pic1pic2pic2pic3pic3pic4pic4pic5pic5
  • 173
  • 47
  • 55
Message 2 of 8
Re: Quick Installation help required (with pictures inside)
I can help with this. I will DM you.
Paul
  • 225
  • 31
  • 37
Message 3 of 8
hi waiting for pics to load will get back to you when they have. usually takes a while
Message 4 of 8
thank you. could you see the pictures?
  • 71
  • 14
  • 9
Message 5 of 8
Hi there
You should have a wedge shape box on the wall with a connections point inside.
Wedge will have ntl,comtel,telewest or virgin media on it.
The coax cable you have been sent will connect to this.
Unfortunately you pictures are not show up on your post.
Hope this helps.
  • 225
  • 31
  • 37
Message 6 of 8
hi not yet usually take up to 30 mins to load
  • 225
  • 31
  • 37
Message 7 of 8
hi can now see your pictures can you PM me a number i can ring to talk you through the connections?
Message 8 of 8
This is now sorted! Thanks Adrian
