Kaz11Cedars
Problems with installing hub 4
I had hub 3, no problems. Cant connect hub 4 due to isolater cable not compatible with wall socket.(no wall socket just a cable which says Con 3 with a technitix socket!!)
Rang virgin media & they are sending out new cables! Tried to explain about the cable coming up from floorboards being screw in not push,  & needing an engineer but their not interested  its cables or nothing they can do!! Any Ideas?
carl_pearce
  • 1.76K
  • 113
  • 377
Super solver
Re: Problems with installing hub 4
The HUB 3 and HUB 4 use the same connector.
Could you post a picture of what you mean?
Roger_Gooner
  • 8.74K
  • 557
  • 1.66K
All you have to do is remove the coaxial cable from the hub 3 and use it to connect the hub 4.
Hub 3.0, TP-Link Archer C8, TP-Link TL-SG108S 8-port gigabit switch, V6
My Broadband Ping - Roger's VM broadband connection
Lee_R
  • 6.87K
  • 321
  • 735
Hi Hi Kaz11Cedars, thanks for posting and welcome to our community.
Sorry to hear that you've been having issues connecting your hub 4.  Have you been able to follow the advice from @carl_pearce and @Roger_Gooner ?  They're correct in the advice they've given.  If you're still having difficulties, please could you get back to us?
Lee_R
