Power plug not working for wifi (quickstart)
Hi I've got a broadband package from VM and they have sent me out quickstart box,
I've plugged everything in but its not working. On my hub I have a green WiFi light, flashing green arrows and every now and again it goes red and then the base light is solid green.
Now I have noticed on the main white plug that goes into the wall, there is a light that should be green but this is not lit up.
I've been at this for 4 hours now 😩 😫 I was on hold to VM for 56 mins and then at 6pm automatically got cut off..............
PLEASE HELP
  • 7.01K
  • 517
  • 907
Legend
Re: Power plug not working for wifi (quickstart)
Hub Activation number -  0800 953 9500
Mike Robinson
Aircraft Engineer & Computer Based Training and Learning Designer for many of the world's Military Arms.
Thanks Mike, been trying that number for a while........ says having trouble connecting you, but can transfer to someone who can help then says offices closed
  • 84
Dialled in
Try 0345 454 1111 and see if the automated service will connect you and activate equipment.  I had same last week and once equipment activated the green supply light on power point came on.
R SCOTT
