Power levels and internet issues
dieseldog57
Hi folks, noticed my internet can be a bit laggy at times. Found my power levels seem slightly on the high side.
Ill post below my logs.
Any advice
Cheers
3.0 Downstream channels
133100000017.643QAM 25625
213900000014.741QAM 2561
314700000014.842QAM 2562
415500000014.942QAM 2563
51630000001542QAM 2564
617100000015.142QAM 2565
717900000015.242QAM 2566
818700000015.342QAM 2567
919500000015.542QAM 2568
1020300000015.542QAM 2569
1121100000015.742QAM 25610
1221900000015.641QAM 25611
1322700000015.540QAM 25612
1423500000015.242QAM 25613
1524300000014.742QAM 25614
1625100000014.241QAM 25615
1725900000014.642QAM 25616
1826700000015.242QAM 25617
1927500000015.742QAM 25618
2028300000016.142QAM 25619
2129100000016.442QAM 25620
2229900000016.642QAM 25621
2330700000016.842QAM 25622
243150000001743QAM 25623
2532300000017.343QAM 25624
2633900000018.142QAM 25626
2734700000018.443QAM 25627
2835500000018.343QAM 25628
2936300000017.643QAM 25629
303710000001743QAM 25630
313790000001743QAM 25631
1Locked43810
2Locked41846339
3Locked42237274
4Locked42283179
5Locked425341711
6Locked4222533
7Locked4221816
8Locked42785413853
9Locked421630
10Locked421030
11Locked42510
12Locked411080
13Locked40240614
14Locked42980
15Locked42920
16Locked41860
17Locked42600
18Locked42680
19Locked42680
20Locked42700
21Locked42770
22Locked42800
23Locked42880
24Locked43990
25Locked431120
26Locked421030
27Locked43970
28Locked431200
29Locked431300
30Locked431720
31Locked431940
3.1 Downstream channels
41944K1840QAM 40961108
41Locked4215.8166391588211
5 REPLIES 5
Legend
It is worth calling 0800 561 0061 to see if there is a known fault.
The downstream signals are 50% above the normal maximums.
Unless a 10dB attenuator has gone AWOL from your cable to the Hub, this looks like Mr Fingers moved your connection to a higher power tap in the street cabinet and that has taken the signal well above acceptable levels.
jpeg1
A lot more than 50% high. It's a logarithmic scale.
- jpeg1
My name is NOT Alessandro. That's just a tag Virginmedia sticks on some contributors. Please ignore it.
Matthew_ML
Hey dieseldog57, thank you for reaching out and I am sorry to hear you are having some connection problems.
I have taken a look at our side and I can't see any major everything is look great your levels are very good.
Please can you post your BQM here. Cheers
Matt - Forum Team
New around here?
Legend
Either Matthew_ML does not understand the DOCSIS power standards or he urgently needs an appointment at Specsavers !
dieseldog57
Just thought id update everyone. It seems there was an attenuator missing from my line, re wired everything and now within specs 🙂
Thanks for your help and advice.
