colin14
  • 7
Message 1 of 7
Power adapter for 360 box wrong size.
Hi,  Can anybody from VM help please. The power adapter that came with my 360 box is the wrong size, the plug that should go into the back of the 360 box is too big (6mm diameter) it should be 4.5mm diameter. I contacted VM via live chat, said they would have one sent out, they sent me a remote control!
Regards,  Colin Hughes.
Z92
  • 2.28K
  • 189
  • 357
Problem sorter
Message 2 of 7
Re: Power adapter for 360 box wrong size.
Doesn't surprise me in the slightest to be honest.
You are better going down the "HUB doesn't work, no lights, please replace" route. I know you only want the power supply but asking for the entire thing to be replaced is typically simpler and likely to at least get you the correct parts (well you might get another 360 with the wrong power supply, but at least you'll get a power supply...)
colin14
  • 7
Message 3 of 7
Thanks Z92, It's the power adapter for the 360 tv box that is the wrong size, do you mean I should say "360 tv box doesn't work, no lights, please replace".
Z92
  • 2.28K
  • 189
  • 357
Problem sorter
Message 4 of 7
Sorry, yes, you just need to make it as clear as possible that it's broken and they'll send you another.
As soon as you start talking about individual parts things get confused, hence why you got a remote control. It's the most commonly requested part.
colin14
  • 7
Message 5 of 7
Thanks Z92.
David_Bn
  • 4.95K
  • 227
  • 403
Message 6 of 7
Hi colin14,
Thanks for your post on our Community Forums and a very warm welcome to you!
Can you please confirm if we've since been able to get the cable to you and this has now resolve the issue for you?
Kindest regards,
David_Bn
colin14
  • 7
Message 7 of 7
Hi David_Bn,
Yes the issue is resolved. Molly_G replied to my post and within 2 hours Bob a VM tech arrived with the correct power adapter. Absolutely brilliant service! A big thanks to all 👍.
