sayekm
  • 330
  • 29
  • 64
Fibre optic
Message 1 of 13
Post a replacement interior white cable please 50cm long
The cable that connects from the wall socket to the modem is only 30cm long when it was installed.
I have replaced the surround furniture and now its difficut to position the modem.
Would it be possible to post a longer cable about 50cm? This cable does not require a enginner visit as its no different than the self install pack cables..
I only have 6 weeks left on the contract so if it can't be sent by post other option is cancel the contract and get new contract in partners name and request free enginner visit which is waste of enginner visit.
xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
M200 Oomph - 5GB SIM + 3 extra SIM family plan - BT whole Wi-Fi - Sky Q
Don't cry over Virgin price increase instead speak to retentions team and negotiate a better deal.
Z92
  • 2.59K
  • 208
  • 415
Trouble shooter
Message 2 of 13
Re: Post a replacement interior white cable please 50cm long
You can't get a free engineer by cancelling and signing up again, you'll probably get 14 days without any service to switch over the contracts and then a £35 charge for a "manned installation fee" compared to a free install for a Quickstart/Do it yourself installation, and don't forget the £35 activation charge as well...
Customer services will probably also request you send the current equipment back and they'll send you new equipment for new contract, then it'll get lost in the post!
Must agree though, that cable seems a little short, mine is looped around the floor it's so long, I'd love to have a smaller cable! I'd swap with you but I don't fancy being without broadband for a week.
jpeg1
  • 5.43K
  • 284
  • 895
Superstar
Message 3 of 13
What you could do (I haven't suggested this of course!) is to complain that your existing cable has been damaged and ask to be sent a replacement. Then you have two 30cm cables. Get a back-back connector for a couple of quid and you have a 60cm cable. 🙂
sayekm
  • 330
  • 29
  • 64
Fibre optic
Message 4 of 13
I am a light user on M100 service and it was free engineer setup plus a £75 credit on account when i joined.
Virgin always doing promotion for free setup for new customer setup via price comparision websites 🙂
I am not a heavy user like the big boys on M350 and M500 so have no issues going back to Talktalk and some cashback.
You must have those pre-made self instal cables if very long.
I wonder next time I spot a VM engineer on the road I donate some lunch money in exchange for a cable 🙂
sayekm
  • 330
  • 29
  • 64
Fibre optic
Message 5 of 13
I did call customer service and they dont have such cable..they can only send a replacement ethernet cable 😞
I need to spot a VM engineer on the road. normally there are so many in my area.
stabilo00
  • 281
  • 36
  • 57
Fibre optic
Message 6 of 13
Don't tell anyone but Screwfix sell one that works fine but it is against virgins terms to use.
Keith d
Gaz82
  • 16
Message 7 of 13
Or just go on Amazon any buy a short RG6 cable yourself - You can buy them with the compression F type connectors already added for a few quid. Something like this:
https://www.amazon.co.uk/1STec-Isolator-connecting-Splitters-Broadband-Black/dp/B07NQ9ZFH9/ref=sr_1_...
sayekm
  • 330
  • 29
  • 64
Fibre optic
Message 8 of 13
Thanks for all the suggestions guys 🙂
I dont want to risk it with 3rd party cables incase 1 day engineer visit is needed for an actual fault and they spot 3rd party cable.
I shall look for VM enginner on the roadside and offer them lunch money 🙂
  • 26.33K
  • 2.69K
  • 4.88K
Message 9 of 13
Never use non-VM cables - my daughter did for her V6 - after VM tracked down the whole neighbourhood's issues were being caused by it - we were lucky to get away with no charges after violating our T&C's !
I thought VM included made-up 3m cables in quick start packs these days - is that not correct - anyone?
You might get friendly engineer but dont bank on it as changing the length of the cable can alter the power levels on the Hub and these would then need to be reset by the techy. If you want to have it rewired and set up exactly where you want it VM will do that for you for a £99 no-fault call out charge.
Whether you regard that as expensive for a lunch - depends on you tastes 🙂
sayekm
  • 330
  • 29
  • 64
Fibre optic
Message 10 of 13
I only need a extra 20cm longer cable.
My power level very high so if anything the extra 20cm should lower the power.
But I will only use genuine VM cable.
1202750000840256 qam9
22107500007.640256 qam10
32187500007.540256 qam11
42267500007.540256 qam12
52347500007.540256 qam13
62427500007.540256 qam14
72507500007.840256 qam15
82587500007.840256 qam16
92667500007.540256 qam17
102747500007.640256 qam18
112827500008.140256 qam19
12290750000840256 qam20
13298750000840256 qam21
143067500007.640256 qam22
153147500007.940256 qam23
163227500007.340256 qam24
173307500007.340256 qam25
18370750000740256 qam26
19378750000740256 qam27
203867500006.440256 qam28
213947500006.440256 qam29
224027500006.840256 qam30
234107500006.940256 qam31
244187500006.540256 qam32
12579996650.3512032 qam4
24619996049.8512064 qam1
33939995050512064 qam2
43260001051512064 qam3
