Mojo74
Poor picture quality on virgin box
Poor picture quality when watching tele through virgin box
ok on other channels prime Netflix etc
need help please as call centre no help
  • 10.48K
  • 1.44K
  • 3.09K
Re: Poor picture quality on virgin box
Hi Mojo74,
Have you looked at Check service status at the top of the page? You can also a run a test on your equipment from there.
If nothing is showing  you could also try the  Service Status number  0800 561 0061.  This often gives details of more local issues down to postcode level.
Which box do you have. if you aren't sure please check <<< this page >>>  as it may help us pin down the problem.
What do mean by poor picture quality?
Is the picture pixelating?  Does this happen on all channels or just certain ones.
Please can you advise of a few channels and whether they are HD or SD.
Any problems with On Demand, Catch Up or apps?
Dave
LittleMick73
  • 5.39K
  • 547
  • 923
Superstar
Hi when you post a question like this you need to provide more information, what virgin box, type of TV what are the settings on the virgin box set at etc. Regards Micky
