Just joined
Phone connection rj45 not rj11
Have fibre zoom 500. Engineer setup phone connection via rj11 plug port 1. I have bought a cisco ip phone and connection is via lan. How can I connect and get it to work. Would a rj11 - rj45 adapter work ? The phone is POE . I have had nothing but trouble recently with all of this . Please can someone assist me
  • 15.4K
  • 1.71K
  • 3.53K
Re: Phone connection rj45 not rj11
You don’t need an internet phone for a Virgin phone line. The Virgin phone service is not VoIP, it just uses the Hub to transmit over the DOCSIS RF network to the local cable headend telephone exchange. Calls do not use the internet. Any ordinary landline phone plugged into the RJ11 to BT adaptor (that should have been provided) will do.
Virgin BB TV Landline. Freeview/Freesat HD, Virgin Mobile, Tesco Mobile. Cable customer since 1993
  • 4.78K
  • 877
  • 1.26K
Hello
By chance are you a VM Business Customer, as the Zoom 500 package is a business package the hub you have is it a Hitron ?
If it is you will need to contact business support as this forum can only give advice for VM Business Customers as the forum is for Consumer Support only, you can contact them on https://www.virginmediabusiness.co.uk/help-and-advice/get-in-touch/contact-us/
Regards Mike
