on 11-06-2023 21:31
Hello my virgin media internet cable has been cut from the outside by accident can this be temporarily fixed till a VM engineer comes out.
on 11-06-2023 21:36
Who will perform the temporarily fix ?
on 11-06-2023 21:38
depends how long they will take to do the repair, and if the cable has slack in it.
on 11-06-2023 21:45
Has some slack, would it effect in anyway or breach any rules VM if attempted to temp repair yourself?
on 11-06-2023 21:55
Most likely an electrician.
on 14-06-2023 08:31
Hi @lms82
Thanks for posting on our community forum and sorry to hear about the issue with your broadband.
After a remote check I can see the tech visit took place yesterday and the issue now seems to be resolved. How are you getting on now?
on 15-06-2023 16:12
Hi, an engineer fixed my broken cable but I need someone to attend and bury it deeper it is exposed to anyone walking past and seen as it's linked to my alarm it's a security risk, can you help in any way talking to customer service team is like talking to a brick wall sometimes.
on 15-06-2023 16:44
It should have been inside some green conduit and buried deeper.
on 15-06-2023 18:52
Nope, he said he just came to splice the cable back together, it's someone else's job to do that 🤷♂️
