Yogeshprasad
Outside Brown Box - Not properly secured
Our Virgin media outdoor wall junction box (brown coloured) has an improperly secured cover.  It seems to fall off since it was installed.  I am concerned that due to high winds and rainfall, it can cause more problems now.
Can someone advise how I can get this sorted out?
Yogesh
Anonymous
Not applicable
Re: Outside Brown Box - Not properly secured
the omniboxes are not water proof anyway it should be fine. a wire tie around it should hold it closed
Yogeshprasad
Thank you.  That’s reassuring.  I have put a duct tape now for the second time.  As I see it, there is a lot of wire and the box is not closing properly.  They may need to replace the box.
