on 01-12-2022 21:00
Have got problem setting up QS broadband.
Wall box connection isn’t push in,it has a thread(and hexagonal nuts) Probably 12+ years old.
Do I need an engineer to update it?
Answered! Go to Answer
on 01-12-2022 23:02
The new push type fittings are designed to just push over the threads on an existing socket.
01-12-2022 21:13 - edited 01-12-2022 21:27
Does your connection still have a cable terminator cap fitted (the 'hexagonal nuts' in your description)? As per these
https://www.amazon.co.uk/F-Type-Terminator-Cap-Coaxial-Satellite-Connector/dp/B01LTBJ5JA
If so, these are required on unused cable connections but are removed in order to make a new connection to equipment.
Post up some clear photos of your wall box/connections which will help identify what you have in place and what you should connect to.
on 01-12-2022 23:02
on 01-12-2022 23:37
Thanks for replying. There are no caps on the two connector prongs, they are just there. There is hexagon on that on the incoming cable.Thanks for replying. This is what we’ve got. There are no end caps on. The hexagonal nut is on the incoming cable on the left. The Person below has suggested that we can push the new connector over the threads. Does that look right?
on 02-12-2022 10:49
You can try push fitting the VM lead provided by VM onto either one of the two outputs of the splitter. See if you can get connected.
If you are only connecting one piece of equipment, you don't need the splitter (which is marked with an insertion loss of 3.6 dB and should ideally have a terminator cap on the unused connection).
If the white cable is the incoming VM cable you could remove the splitter by unscrewing it from the cable but you would need to get an F-connector coupler like this though
https://www.diy.com/departments/slx-f-type-satellite-cable-coupler/5028422001905_BQ.prd
to be able to join the two plugs together.
If you want to avoid the trailing lead altogether, would need a VM tech to fit a wall box for you which might be most suitable for long term use.
Try connecting to the splitter first and see if you can connect at all.
on 02-12-2022 12:19
I have the same problem.... same type of connection with the old splitter.
Everything is plugged in but the modem box keeps flashing red
on 02-12-2022 12:42
@DavidBana wrote:I have the same problem.... same type of connection with the old splitter.
You would do best to stick to your own/original topic
https://community.virginmedia.com/t5/QuickStart-set-up-and/Flashing-red-light/m-p/5193545
multi-posting just causes confusion when the same question is asked in different places. It normally takes the VM forum team two or three days to reply to each person's topic.
on 03-12-2022 09:43
Thanks for your help, I’m connected now. Will sort the wall box out next
