Apples123
No wall box - but there are cables
Hello,
Just ordered the Quick Start with Virgin as the previous house owners were on Virgin. However, the wall box isn't present inside, but we do have this cable coming into the house (which attaches directly from the brown Virgin box outside the house).
We also have these cables, which (I think!) were attached to the wall box before it was removed.
Are we likely to have everything we need to set up? (except the actual plastic wall box).
Any help much appreciated!
  • 5.61K
  • 461
  • 1.42K
Re: No wall box - but there are cables
Just get one of these for the black cable and the quickstart cable will just push on.
Tristar Data cable coupler | DIY at B&Q
However, that also looks like a powered amp, in the other "yellow spotty" picture, so that may need to be sorted by an engineer.  They are usually used when the property is too far from the street cabinet to give a decent signal to the Hub.
-tony-
  • 18.7K
  • 1.43K
  • 4.62K
screw the black cable into the hub and see what happens - if its live the hub should get a white power light ater it goes through its boot routine - that can take a while
if you do get a white light or not you may need to activate the hub - 0800 953 9500 - from there
log into hub3 - 192.168.0.1 [or 192.168.100.1 if in modem mode] - DON'T SIGN IN, click - click router status [centre of screen] - and look at the downstream and upstream figures - to see those press on the grey buttons/boxes labelled - upstream - downstream and inital connection screen
the other item is a powered amp as said or a powered splitter - you may need that if so you need to connect the black cable to the input port and the cable that came with the quickstart to the output and then to the hub - obviously plug the power adaptor in
if non of that makes sense then wait for VM to get to the thread - they should book a tech or ring and just say its not working - leave the hub disconnected if you ring
____________________
Tony
Apples123
Thank you both for this, so helpful.
The Virgin delivery is due at end of the week, so I'll plug in and see what happens.... Fingers crossed we have everything we need.
Thanks for the explanation about the powered amp. I'll assume that if previous owners used it, it'll be likely that we will need it too!
paul0363
  • 569
  • 65
  • 198
Rising star
Post deleted.
Robert_P
  • 4.02K
  • 189
  • 370
Hello Apples123
Thanks for posting in regards to the current cabling and to see what is needed for your new QuickStart order, we appreciate you taking the time to raise this and welcome to the community.
As per usual our forum members have come up trumps and provided you with all of the required information, let us know if you need us again once your delivery has arrived or if you need any help with the set up.
Rob
