Pinnick
  • 36
Message 1 of 11
No tools provided with fibre kit
Howdy
Just had my fibre kit arrive, woo.
However, no tool was provided to install it with. There is a large sticker on the Hub that states it should come with a spanner...
Sooo, anyone know which size spanner I need to buy to install the hub? Also, best route to take to claim the purchase back via Virgin?
Kind regsrds
  • 6.09K
  • 512
  • 1.57K
Message 2 of 11
Re: No tools provided with fibre kit
@Pinnick wrote:
Howdy   Just had my fibre kit arrive, woo.
<snip>
The new quickstart kit is a push on fit, the spanner is not required.  By the way, the "spanner" just a tiny plastic one, worth about 5p.  🙂
Pinnick
  • 36
Message 3 of 11
@adduxi
That is great, news. And undoing my old equipment, would that simply pop off, too?
  • 6.09K
  • 512
  • 1.57K
Message 4 of 11
@Pinnick wrote:
@adduxi
Ahh, it depends on the state of the existing connection.  The older ones will be a screw fit, and "should" unscrew, depending on layers of paint, any corrosion etc.  Hopefully you will get lucky and and old cables will unscrew by hand.
Pinnick
  • 36
Message 5 of 11
Thank you 🙂
I'll try this after work.
Saved VM 5 pence there!
  • 12.88K
  • 1K
  • 2.58K
Message 6 of 11
Because it’s plastic if the F plugs have been tightened a lot it is useless. Just use an adjustable spanner, a ‘mole’ wrench or plain old pliers. I have even known people to use nutcrackers!
Richw1982
  • 503
  • 34
  • 121
Rising star
Message 7 of 11
The screw f type connectors should be around 8Nm tight.  If they are just finger tight it can cause ingress and noise on the network.  Nutcrackers work a treat though
Rich
I work for VMO2 but all opinions are my own and are based on my own experiences
Pinnick
  • 36
Message 8 of 11
Thank you 🙂
It's all installed.
How can I tell if there is noise on the network?
  • 6.09K
  • 512
  • 1.57K
Message 9 of 11
@Pinnick wrote:
<snip>
Normally shows as PostRS errors in the Hubs Status pages.
  • 33.7K
  • 3.3K
  • 6.4K
Message 10 of 11
One place to look is in the table of RS errors in the downstream data. Ideally all should be 0 and stay 0. A few PreRS errors is not a big problem thousands are - but - if there are accumulating PostRS errors in any channel - that usually indicates noise getting in.  Also T3 errors on the upstream channels is an indicator too.
