pauljermany
  • 7
Message 1 of 13
No Broadband Connection - HUB3
Hi, after a frustrating evening yesterday speaking to 4 people on the VM Help Lines I just have not got anywhere. Later today I will have been 48 hours with no connection! My HUB3 is displaying all the right signs of working, the VM Tests say it is okay - but there is no data going through it. How do I proceed from here?  I don't want to waste another precious evening on the phone to people that don't seem to have a clue and can only think WiFi is the problem to everything, the HUB3 just isn't working!  VM please help me here!
Z92
  • 2.29K
  • 190
  • 359
Problem sorter
Message 2 of 13
Re: No Broadband Connection - HUB3
What exactly isn't working?
Do you have no WiFi?
Do wired connections also not work?
On a PC, can you access http://192.168.0.1 ?
Have you tried rebooting the hub by turning it off at the wall, waiting a few minutes then turning it back on?
Have you tried a factory reset?
pauljermany
  • 7
Message 3 of 13
What exactly isn't working? - No Internet Connection through the HUB3
Do you have no WiFi? - Not Applicable in this case, it's the Internet Connection that I don't have, using direct cable connection for now
Do wired connections also not work? Correct, Cable connected from Laptop to HUB3 to rule out anything else - nothing
On a PC, can you access http://192.168.0.1 ? Possibly, have not tried this yet as I can't see it helping, cable itself is good and shows indicator lights at the connections
Have you tried rebooting the hub by turning it off at the wall, waiting a few minutes then turning it back on? - Yes, several times
Have you tried a factory reset? - Yes, several times - also VM Help have done this, also switched WiFi/Router Modes - nothing
pauljermany
  • 7
Message 4 of 13
What I didn't make clear, when I probably should have - This is not a New Install, it's been installed a good few years now and with minimal problems - just seems like it's died...
Z92
  • 2.29K
  • 190
  • 359
Problem sorter
Message 5 of 13
Accessing http://192.168.0.1/ will most definitely help as from there you can click "Check network status" below the password prompt (or similar wording) and we can then tell exactly what the problem is.
jpeg1
  • 4.53K
  • 254
  • 729
Superstar
Message 6 of 13
The reason for connecting to 192.168.0.1 is that you can click on Check Router Status and report here the various connection data.  This will give a clear indication of the problem.
///Crossed with Z92.
pauljermany
  • 7
Message 7 of 13
Okay, thanks - will post back around 18:00 when I get home...  Wouldn't VM Help be able to have seen this yesterday evening though?
Z92
  • 2.29K
  • 190
  • 359
Problem sorter
Message 8 of 13
Yes, but considering their level of technical expertise, it would typically go something like this:
"You might need a WiFi booster",
"There could be too many devices connected to your WiFi."
and if you still persist:
"We've sent a signal to your hub, please give it 15 minutes and it should work then" => We've remotely rebooted your hub.
pauljermany
  • 7
Message 9 of 13
Okay, just connected laptop directly to hub 3, cannot connect with 192.168.01 it returns an error: err_connection_timed_out  i have tried another ethernet cable just in case, still nothing. Also tried other ports on the hub 3, nothing there either 🙄
pauljermany
  • 7
Message 10 of 13
Just connected the same set up to another hub 3 in another house , it all works fine, can access the settings too! Looks like my hub 3 is dead...
