Next door neighbour has virgin broadband but won’t show up for me.
seanmcg01365
So I live on a main road in Glasgow ,literally my next door neighbours adress shows up when I put in the postcode but mines is no where to be seen. I’m pretty sure If they could have it then I could too.
Spoke to someone from virgin on the phone and she told me I couldn’t get it. Is there anyone I could speak to or anyway I could find out if it would work? Cheers.
1 REPLY 1
VM-Jon
Problem sorter
Hi @seanmcg01365
Thank you for reaching out to us here, to the community.
Please accept our apologies for the difficulties you are having, I would like to take a look at this for you and see what I can do to help. In order to do so I will need a little bit more detail so I will send you a private message.
Thank you
Jon
Here to help! I'm an install manager helping out whilst working from home. Find out more
