Newly installed Virgin hub3 won't work with TV, Blu Ray or Media Streamer
Panasonic smart TV, Panasonic smart blu ray player, and Cambridge Audio NP30 Media streamer all worked OPK with Hub2. Newly installed hub 3 works fine with PC (hard wired) and 2 x phones and ipad and kindle (all via wifi), but not with the wired connections to the TV and blue ray and media streamer. The network wiring tests out just fine. All are set to auto IP and Auto DNS, so should detetc the router, but don't.
Re: Newly installed Virgin hub3 won't work with TV, Blu Ray or Media Streamer
Solved!
Turns out one internal network cable wasn't connecting correctly.
Swapped it out and all OK.
