kingcest
  • 5
New hub 3.0 faulty power coonection
Hi all. I just got my Hub 3.0 today but its power connection seems to be faulty. It can only get power at a random position and as soon as I move it slightly, the power would go off again. Is there any way to fix this? How can I contact Virgin to get a replacement asap? Thanks.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Re: New hub 3.0 faulty power coonection
You can contact VM to report the problem using ...
Pre-installation & Delivery team on 08000 521 734
Hub Activation number on 0800 953 9500
Text service on 07533051809
150 from Virgin landline.
0345 454 1111 from any other UK  phone.
The best time to call is weekdays 08:00 to get a UK agent, anything after 10:00 you must realise that you are quite likely to get through to an offshore agent that doesn't speak English as a first language.
Or you can wait on here for one of the VM Staff to pick up the thread but this may take a few days.
kingcest
  • 5
Thanks a lot Mike. I have contacted VM and they will send a replacement to me. Many thanks for your help.
