on 21-04-2023 07:01
I recent moved the position of my hub. In its original position it required an extra long white cable, which was supplied and fitted by Virgin many years ago. Now the hub is nearer the wall box (from out of which comes the dual connector into which plugs the hub cable and 360 cable), this has left me with much surplus length of white Hub cable coiled up behind my TV. Ideally I need to replace this using a shorter cable of no more than 1m.
Are Virgin able to supply the shorter cable for me to install myself or would this require an engineer visit to fit the shorter cable ?
Alternatively I note there are supposedly compatible cables available on line. Do these work or do I need a cable supplied specifically by Virgin ?
(note it is the cable from hub to wall I am talking about NOT the cable from 360 box to wall !!)
Any help appreciated
Answered! Go to Answer
21-04-2023 09:22 - edited 21-04-2023 09:23
@Client62 wrote:VM internal cable is RG6 coax with F-Plugs - Amazon etc.
poor advice - VM cable is specific to them - there are many sold elsewhere that are said to be ok - they may be they may not be so not a good idea - there are always a few on ebay that are genuine so that is a better choice
or pay VM £25 to sort it
and - yes - if you change the cable and re boot the hub it should connect
on 21-04-2023 07:07
on 21-04-2023 07:24
Thanks.
And if I self install this, when I re-book the hub, will it simply start working again as normal once it's powered up, or is there a whole set up / installation procedure to go through with it?
on 21-04-2023 07:26
on 21-04-2023 09:27
https://www.ebay.co.uk/itm/145002144593 - there you go
21-04-2023 09:28 - edited 21-04-2023 09:30
There are many varieties ties of cable called RG6, it is a very loose specification.
on 21-04-2023 10:55
You can buy RG6 cable that is entirely unsuited to this application due to inadequate screening that will let in noise.
The term, RG-6, is generic and is applied to a wide variety of cable designs, which differ from one another in shielding characteristics, center conductor composition, dielectric type and jacket type. https://en.wikipedia.org/wiki/RG-6
Here are just one reputable manufacturer's types of RG-6. Unbranded types on the web could be anything.
on 21-04-2023 11:08
another https://www.ebay.co.uk/itm/145002146057
on 23-04-2023 14:12
Hi Gary-C-1971,
Thank you for reaching out to us here on the Community.
We would be happy to assist with the set up of your equipment.
In order to supply the correct cable and complete the set up, we would need to arrange a visit from one of our technicians. This would be charged at £25.
If you wish to proceed with booking the appointment please reply to the private message I have sent over to the purple envelope on the top right of this page.
