MRM3
  • 27
Message 1 of 20
Need help regarding New Hub coming-Home Phone Switchover
1.Received a letter from Virgin stating I needed a new Hub to connect my home phone to.
This is all new to me, so I am seeking advice.
Does someone come and do it, or is it just a case of plugging it in if it's delivered?
And setting it up?
2. Also, sorry to be ignorant lol but....
Will it be a new name which means I will have to change it on my Phones, Tablets, 2 Echo dots, smart plugs, Wi-fi Extender, Chromecast, Firestick, TV and Computer?
Thought it would be a simple job but now am worried.
  • 15.85K
  • 2.1K
  • 4.98K
Message 2 of 20
Re: Need help regarding New Hub coming-Home Phone Switchover
Hi @MRM3
When you receive your new hub it will have a different SSID and password to your current hub.
You can though log into the hub settings and change them to match your current SSID and password.
Details of how to do that are shown on this page
 https://www.virginmedia.com/help/broadband/change-wifi-name-and-password
It should just be a case of plugging in the new hub to replace your existing hub, then plugging the phone adapter into the phone socket on the new hub.
The info below is from  the following page
https://www.virginmedia.com/help/landline/switchover
 On the day of your switchover, unplug the phone cable of your main phone (or base station if it’s a cordless phone), from the wall socket. If you have any other devices connected to this socket, or you use internal phone sockets around your home, please give us a call.
2. Grab the adapter we provided and plug it in to the top grey port, Port 1, on the back of our Hub.
3. Now, plug the end of the telephone cable you unplugged from the wall socket in to the adapter.
4. Wait a couple of minutes for a dial tone, then make a test call. Your new services from Virgin Media are all set up and ready to use.
Dave
Love, love and love, forever - Pele
MRM3
  • 27
Message 3 of 20
Thanks NewApollo
The pc and Hub are in one corner of the room
The white Cable comes in diagonally across the room (Behind TV) over a door frame etc etc
No socket behing Pc and Hub
Very confused sorry
goslow
  • 5.47K
  • 739
  • 1.97K
Superstar
Message 4 of 20
@MRM3 wrote:
Thanks NewApollo
Very confused sorry
If you are getting a new hub as part of the phone switchover (often because an existing hub 1 or 2 has no phone socket on the back) then VM would normally send a technician, who will bring the new hub, and set it up for the new phone service.
You would need to connect your own wireless devices yourself to the new hub's wireless settings once it is up and running.
Your phone would then plug in to the back of the VM hub, using an adapter provided by VM, as below
MRM3
  • 27
Message 5 of 20
Thanks. I really hope an engineer comes to do it as not super confident.
MRM3
  • 27
Message 6 of 20
Read that it is possible to change the WiFi names back to the ones I have now.
Would that make everything re connect by themselves? Or am I too hopeful ?
  • 13.88K
  • 1.07K
  • 2.81K
Message 7 of 20
Yes, if you change the SSID on the new hub to be the same as the old hub all devices should connect seamlessly.
paul0363
  • 619
  • 66
  • 218
Rising star
Message 8 of 20
Unless you connect a PC to the new hub  via a wired connection, you'll need to change the WiFi settings on one device to the new default Hub settings (as shown on the card that comes with the Hub) in order to connect and log in.  Once you've changed the SSID and Password you'll then need to change that one device back to its original settings.
MRM3
  • 27
Message 9 of 20
Thanks.
At the moment my computer is connected by Ethernet cable.
Not looking forward to the New Hub coming if I should have to figure it out for myself.😁
Never looked in the Hub Settings for years as nothing changed.
However thanks to this forum I am learning a lot
Hoping someone will come with the Hub and help me. and not just deliver it.
MRM3
  • 27
Message 10 of 20
My password is all lower case letters
VM says password has to be 10 characters - 1 uppercase letter -1 lowercase letter - and a number.
So how will I be able to connect exactly the same anyway??
