Need circular cover for green cable duct in pavement
Romseyman
Hi I am having drop kerbs installed in the pavement outside my house. The Council are insisting that I contact Virgin to provide a cover for the green circular cable duct in the pavement outside my house before work commences. I have tried many times unsuccessfully to find out who to contact in Virgin to organise this. Has anyone got a contact point to resolve this please.
1 ACCEPTED SOLUTION
Accepted Solutions
nodrogd
What you have is probably a legacy termination over. There is only one type VM installs now, & that is a TOBI fibre termination box. This is larger than the older covers, so can require a full construction team to install it.
Tobi boxTobi box
VM 350BB 2xV6 & Landline. Freeview/Freesat HD, ASDA/Tesco PAYG Mobile. Cable customer since 1993
8 REPLIES 8
goslow
Do you mean a cap to go on the end of a piece of green conduit sticking out of the ground or a circular cover plate to cover an access point in the pavement?
Post a photo of the thing you want to cover/block which might help the VM forum team.
Carley_S
Hi @Romseyman
Welcome back to the community forums
Sorry to hear that you've been trying to contact us regarding external works to allow your drop kerb request to go ahead.
Are you able to provide any images of the cover that is needed to be replaced or the area in which the cover will be replacing?
We are able to support further with more detailed information as we might be able to raise this with them correct team to support further.
Here to help 🙂
Virgin Media Forums Agent
Carley
Hi, have you had any success sourcing the cap for the virgin cable duct please.
Charles
nodrogd
Tobi boxTobi box
Thanks for the response.Apparently what I require Is a black plastic cap which clips over the top of the 50mm duct protruding slightly from the pavement .
nodrogd
@Romseyman wrote:
They won’t fit one of these now. These were installed by the first cable companies to operate in the UK & are a very cheap way of duct termination. They also have the habit of leaking like a sieve & flooding the ducts during heavy rain. Hence they stopped fitting them as they are more trouble than they are worth.
goslow
You might have a very long wait for VM to provide you with that thing. See if you can find something similar online
https://www.ebay.co.uk/itm/266001705282
for the correct diameter
jpeg1
Here is the contact you need.
Virginmedia will require payment for any work that is needed.
https://www.virginmedia.com/help/diversionaryworks
- jpeg1
My name is NOT Alessandro. That's just a tag Virginmedia sticks on some contributors. Please ignore it.
