Cut a long story short, one of the LAN ports on a relative's late 2019 Hub 3 died on Saturday night during storm over SE London area. The Hub 3 was set up in Modem mode for past 2 years, displaying purple/magenta power light. An external Asus router was wired to the now faulty LAN port.
On Sunday, when Virgin customer services advised us there was no outage and the hub appeared to be fine apart from lack of wifi, probably because the Hub was in modem mode (magenta power light). We later factory reset the Hub3 to investigate.
The Hub 3 eventually booted up in regular wireless router mode. Quick test on ethernet and wifi seemed to suggest internet access was working. However the power light refused to change from solid yellow to bright white after multiple reboots. It used to be 'white' colour back in 2019/2020 before switching to modem mode.
According to my physics, the colour white is made by combining Red, Green and Blue together, like a TV screen.
Yellow is made from combining Red and Green together. Blue not required.
However, when the Hub 3 is in modem mode, the power light is magenta.
Magenta is made from combining Red and Blue together.
If Blue had failed, then the power light ought to have been displaying confusing Red colour in modem mode.
The speculation on this forum is the yellow power light is caused by faulty multi function LED does not seem to stack up in our case?
I have noticed the layout of the Hub 3 menu looks different to when I last logged into the hub back in early 2020. Is it possible the yellow power light is simply a software bug?
The Hub 3 is now back in 'Modem mode' with magenta power light, with Asus router connected to one of the three remaining functioning LAN ports. Internet access seems to be fine, 6+ hours later.
Virgin also need to review and edit the web page:
https://www.virginmedia.com/help/broadband/virgin-media-wifi-not-working
Description states White power light on and WiFi light is flashing green, but the graphic below description in above page clearly shows flashing GREEN power light and solid green WiFi light.
