paramount197
Message 1 of 8
Mix up and cut wrong cable
I was getting the broadband installed in my property and after a mix-up, Sky TV cable was cut and the same drill-hole was used to set up Virgin broadband.
Could someone guide me what should i now do to fix this issue.. please
Tags (4)
Roger_Gooner
  • 6.61K
  • 481
  • 1.15K
Legend
Message 2 of 8
Re: Mix up and cut wrong cable
Normally you'd call Sky to fix a problem, it usually costs £65.
Hub 3.0, TP-Link Archer C8, TP-Link TL-SG1008D 8-port gigabit switch, V6
Travis_M
  • 618
  • 27
  • 55
Message 3 of 8
Hi @paramount197
My apologies for the inconvenience! You'd first of all need to contact Sky in order for the cable to be fixed as this isn't something we'd be able to sort on our part. Let us know how you get on communicating with Sky and we'll take this from here.
Regards​​​​​​
Travis_M
paramount197
Message 4 of 8
@Travis_M
As the Sky cable was cut during the Virgin media installation, would Sky be responsible to fix it
Tags (1)
Travis_M
  • 618
  • 27
  • 55
Message 5 of 8
Hi @paramount197
Sky would need to fix the cable as it's their own equipment and if it needs replacing or what not, we wouldn't have that equipment at hand.
Travis_M
LittleMick73
  • 4.98K
  • 518
  • 849
Superstar
Message 6 of 8
Hi they are the only ones that can fix thier systems, it's been intimated by a virgin person they may be willing to make a gesture. Regards Micky
nodrogd
  • 16.61K
  • 1.95K
  • 4K
Message 7 of 8
@paramount197 wrote:
@Travis_M
Virgin techs are not insured to work on anyone elses infrastructure, just as Sky employed techs won't work on standard TV aerials.
Virgin BB TV Landline. Freeview/Freesat HD, Virgin Mobile, Tesco Mobile. Cable customer since 1993
Travis_M
  • 618
  • 27
  • 55
Message 8 of 8
Hi @paramount197
I double checked this and once you've contacted Sky, let us know how you get on and we'll investigate this to see if the fee you're required to pay is something we can cover for you on the back of this, obviously providing our technician was at fault for cutting the cable.
Travis_M
