brunobruster
Missing connector for wall socket cable (Hub 3)
I was sent the VM Hub3, power adaptor, ethernet cable and cable to connect the hub to the wall socket. However i am missing the adapter to plug the cable provided into the wall socket.
I have added some pictures below as im not quite sure of the proper names. Can VM send out the adapter?
nodrogd
  • 16.82K
  • 1.97K
  • 4.08K
Re: Missing connector for wall socket cable (Hub 3)
You will need a manned install, as somebody has removed the safety isolator that should be in the wall box. This is what your cable is supposed to connect too.
VM BB TV Landline PAYG mobile. Freeview/Freesat HD, Tesco Mobile. Customer since 1993
brunobruster
Thank you for your reply, can VM not send me the adapter and attach myself?
nodrogd
  • 16.82K
  • 1.97K
  • 4.08K
No they won’t, as they no longer fit that type. They will fit a completely new outlet that is a lot smaller.
