Message 1 of 7
Maximum speed for old Telewest wire & box.
Hi everyone, I am about to sign in for M350 packege and the Virgin web shows that I qualify for a quick start. The flat I moved in some time ago has got two separate lines for Telwest Broadband - a phone line with a standard phone socket and a cable (coax ) line with a box at the end with a single socket for a male f-connector. I know that there are some VB users in my block of flats. My questions are how quickly the service is usually activated and can the old Telewest line support 350Mbs + speed. My top priority is a low latency and a better than everage upload .
  • 11.37K
  • 787
  • 1.6K
Message 2 of 7
Re: Maximum speed for old Telewest wire & box.
Those connectors can support over a Gig so no issues with capacity.
However virgin has higher latency than fttc and upload speeds are only 10%
I work for Virgin Media and my posts are my own opinions
  • 6.17K
  • 459
  • 1.07K
Hero
Message 3 of 7
You should get the advertised upload speed of 36Mbps but, unlike download speeds, there is no minimum guaranteed speed.
Hub 3.0, TP-Link Archer C8, TP-Link TL-SG1008D 8-port gigabit switch, V6
  • 435
  • 72
  • 80
Message 4 of 7
Lead times vary from region to region, i will contact you directly for some details and I will be able to give you a better view.
thanks
Jon, install manager
Here to help! I'm an install manager helping out whilst working from home. Find out more
Message 5 of 7
All , thank you for a quick replay.
The upload speed of 36 Mbps should be enough for me at the moment.The stable low latency is crital.
Jon , you should get my email soon.
  • 2.48K
  • 156
  • 643
Problem sorter
Message 6 of 7
If you want stable low latency then VM probably isn't for you. An Openreach based connection will deliver lower latency.
Have a look at the gaming forum and see if you're willing to take the risk:
https://community.virginmedia.com/t5/Gaming-Support/bd-p/gaming
  • 6.17K
  • 459
  • 1.07K
Hero
Message 7 of 7
Bear in mind that if VM doesn't work you can back out within 14 days at no penalty.
