  • 8
Samit_p
Message 11 of 13
Re: Loss of wired and wireless connection
Is there any specifics that i can point them to? They have been twice and not resolved the problem. Maybe some extra direction could help?
  • 11.8K
  • 1.08K
  • 2.56K
griffin
Message 12 of 13
There is definitely noise ingress on the circuit, you can show them the logs and RS errors, and ask the tech why you are losing the SYNC time stamp.
The trouble with noise ingress is that it tends to be bursty and intermittent and can be hard to pin down.
I take it you have checked your coax cable from the Hub to the cable entry point for obvious signs of damage and all connections are hand tight and there are no un-terminated splitters legs. The Tech should have done it but always worth a quick check yourself.
  • 8
Samit_p
Message 13 of 13
  • Engineer came round today 23OCT19 at apptoximately 1300 and worked on the external equipment where all the individual flat cables go to one wall mounted port/hub/tap. Not sure exactly which components were replaced but the engineer said everything was replaced and is now housed in a lock box instead of exposed to the environment.
After they finished I reset the hub using the reset for 90 seconds. Allowed 2 hours and took the following records from the hub:
Downstream bonded channelsChannel Frequency (Hz) Power (dBmV) SNR (dB) Modulation Channel ID
14027500001638256 qam25
217075000015.938256 qam5
317875000015.938256 qam6
418675000015.838256 qam7
519475000015.938256 qam8
62027500001638256 qam9
721075000015.938256 qam10
821875000015.638256 qam11
922675000015.638256 qam12
1023475000015.938256 qam13
1124275000015.538256 qam14
1225075000015.538256 qam15
1325875000015.638256 qam16
1426675000015.538256 qam17
1527475000015.138256 qam18
162827500001538256 qam19
1729075000015.438256 qam20
1829875000015.138256 qam21
1930675000015.438256 qam22
2031475000015.838256 qam23
2132275000015.638256 qam24
2241075000016.338256 qam26
2341875000016.538256 qam27
2442675000016.838256 qam28
1Locked38.670
2Locked38.650
3Locked38.990
4Locked38.6220
5Locked38.6200
6Locked38.900
7Locked38.960
8Locked38.690
9Locked38.670
10Locked38.960
11Locked38.960
12Locked38.670
13Locked38.650
14Locked38.690
15Locked38.640
16Locked38.650
17Locked38.660
18Locked38.650
19Locked38.9190
20Locked38.960
21Locked38.900
22Locked38.670
23Locked38.630
24Locked38.660
There were no errors showing on the network log but as I was trying to get this together I got a call from the engineer asking to come back to fit an attenuator onto my hub as the signal strength was too high. He fitted a 10db one on the hub 3 port.
I will reset again and post again after 2 hours.
