Yes I’ve done multiple resets and also tried different scenarios of how and when to connect cables etc.
I know the hub is in modem mode correctly because the tv360 box works.
The Ethernet cable from the wall socket goes into port 1 as per the set up guide so that would leave three other ports free to hard wire.
ive confirmed all these ports are outputting internet as I can connect to other devices and tested.
However when I run through the Linksys app it won’t verify the internet?
If you want to give me the basics in case I’m missing something or you can pick any holes in what I’ve done I’m happy to be told I’m being stupid.
