STEVER53
  • 6
Message 1 of 7
LANDLINE PHONE TO HUB 3.0 ISSUE
Hi.
Recently moved house, have connected up everything exactly as was but there's no dialing tone - any ideas or suggestions please?
Steve
Tags (1)
goslow
  • 4.19K
  • 582
  • 1.52K
Community elder
Message 2 of 7
Re: LANDLINE PHONE TO HUB 3.0 ISSUE
@STEVER53 wrote:
Hi.
Steve
If you log into the VM hub, what does it indicate for telephony on the 'Welcome' page?
STEVER53
  • 6
Message 3 of 7
Using the Connect app you mean?
goslow
  • 4.19K
  • 582
  • 1.52K
Community elder
Message 4 of 7
No, using a web browser on your network via http://192.168.0.1 (assuming you are in router mode)
On the welcome screen after login it should look something like this
https://setuprouter.com/router/virgin-media/virgin-media-hub-3/setup-75194-large.htm
check and see if telephony is 'ready' (indicating that the TEL1 socket on the back of the hub has been provisioned for your phone service)
STEVER53
  • 6
Message 5 of 7
Yep, got all that - no sign of any connection beyond the Ready status though, no green phone symbol on the hub either.
STEVER53
  • 6
Message 6 of 7
Lo and behold - it's suddenly started to work!
Don't ask me how, but something triggered it just.
Thanks for your help.
Cheers.
goslow
  • 4.19K
  • 582
  • 1.52K
Community elder
Message 7 of 7
Suspect it was probably the hub had to be powered on for a certain period of time, or something similar. Anyway, glad to hear it has come to life for you.
